Question electrolytic capacitor from 1990`s
This topic is closed.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Question electrolytic capacitor from 1990`s
    Originally posted by gamer87
    I can't use it every day, they're devices from my collection
    Do you ever play/use them ?
    • gamer87
      Banned
      • Sep 2021
      • 12
      • usa
      I have one to play and one stored
      • gamer87
        Banned
        • Sep 2021
        • 12
        • usa
        what reccomendation my case?
          • 31213
          play them for an hour every year or 2 will be more than enough.
          • gamer87
            Banned
            • Sep 2021
            • 12
            • usa
            1 hour of device use is enough to fully reform the electrolytic capacitors?
              • 31213
              it takes very many years to depolarise a standard cap - your being fearmongered by assholes on other forums.
              the type of equipment where we need to worry about such stuff is from the 1970's or older
              • gamer87
                Banned
                • Sep 2021
                • 12
                • usa
                #27
                my devices have electrolytic capacitors from the early 90's
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  Only posting when sober sometimes works, too.
                  ...and reading the stickies will also help...
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                  • PeteS in CA
                    • Aug 2005
                    • 3581
                    • USA, Unsure of Planet
                    #29
                    ... electrolytic capacitors will ... depoarize ...
                    Ignoring the missing "l" (adjacent key errors are my frequent typo type), polarized (= normal) electrolytic capacitors don't depolarize. Very long non-use might lead to the aluminum oxide dielectric layer thinning (probably years of non-use, possibly excepting some cap types with water-based electrolytes), decreasing the voltage the part can withstand, but depolarization won't happen. Being polarized is part of the nature of an aluminum oxide layer dielectric.
                    PeteS in CA
                    • gamer87
                      Banned
                      • Sep 2021
                      • 12
                      • usa
                      #30
                      Electronic devices that use electrolytic capacitors from the early 90's need to be turned on at what frequency of time interval to prevent failures from disuse? i have crt tv, snes, megadrive, ps2 slim, power supply
                      not are new capacitors are capacitors 90s
                      • kasfamily
                        • Aug 2014
                        • 774
                        • Russia
                        #31
                        Here is what is recommended for professional devices ( oscilloscope )
                        • gamer87
                          Banned
                          • Sep 2021
                          • 12
                          • usa
                          #32
                          Does this information only work on new electrolytic capacitors and not on electrolytic capacitors manufactured in the early 90's and early 2000's and assembled in electronic circuits?
                          • kasfamily
                            • Aug 2014
                            • 774
                            • Russia
                            #33
                            1985
                            • gamer87
                              Banned
                              • Sep 2021
                              • 12
                              • usa
                              #34
                              I didn't understand, the manual is from 1985 but the manual was released with the device and that year the electrolytic capacitors of the device were brand new
                              • kasfamily
                                • Aug 2014
                                • 774
                                • Russia
                                #35
                                And in 1986, these electrolytic capacitors were no longer new and it is necessary to do what the instructions recommend.
                                  • 21651
                                  This thread is closed. See attached txt file for the reason why.
                                  • MORETTIGIAN
                                    by MORETTIGIAN
                                    Title:
                                    Description:
                                    Procedure performed:
                                    - Removed backplate
                                    - Reapplied thermal compound
                                    - Reassembled card
                                    09-18-2025, 12:14 PM
                                  • cloudff7
                                    Electrolytic capacitor leak in storage?
                                    by cloudff7
                                    there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
                                    07-22-2024, 06:27 AM
                                  • AleXis6
                                    Manufacturing Date of Electrolytic capacitor
                                    by AleXis6
                                    Guys. could you help me please to decode some codes of main capacitor's producers.
                                    I would like to know the manufacturing date.
                                    Based on the information from capacitors I have - it seems easy to decode manufacturing date for Rubycon, Nichicon.
                                    If I understood correctly:
                                    1. Nichicons marks date of production as (see the attached pictures) H2116
                                    I don't understand the meaning of first letter - may be it is code of factory.
                                    21 -year
                                    16 week
                                    I bought this capacitor recently.
                                    another one-
                                    2....
                                    10-11-2021, 02:20 PM
                                  • Prolog
                                    by Prolog
                                    12-01-2024, 08:27 PM
                                  • beogeek
                                    Need replacement advice for surface mount electrolytic capacitor
                                    by beogeek
                                    I have a faulty monitor, the surface mount electrolytic capacitor 33uF 100V needs to be replaced, now I can't seem to source them locally, so my question is can I replace it with a through-hole electrolytic capacitor of the same value? Or has someone got a better suggestion?
                                    Cheerio...
                                    03-17-2022, 01:43 PM
